如何在CentOS 6 下安裝VPN SERVER(l2tp over ipsec with pre-shared key)
1. 安裝openswan, ppp , libpcap-devel
直接用CentOS裏面即可
2. 安裝xl2tpd(1.2.8)(http://www.xelerance.com/services/software/xl2tpd/)
解開後進入該目錄,執行
make
此時已經可以看到xl2tpd這個檔案了
cp xl2tpd /usr/local/sbin/
mkdir /etc/xl2tpd
cp examples/xl2tpd.conf /etc/xl2tpd/
cp examples/ppp-options.xl2tpd /etc/ppp/options.xl2tpd (這是給以下ppp使用的 sample)
3. 安裝rp-l2tpd (彌補xl2tpd 1.2.4 無法完整編譯)
http://sourceforge.net/projects/rp-l2tp/
下載後解開,進入該目錄,後執行
./configure
make
cp handlers/l2tp-control /usr/local/sbin/
mkdir /var/run/xl2tpd
ln -s /usr/local/sbin/l2tp-control /var/run/xl2tpd/l2tp-control
4. xl2tpd 設定
修改/etc/xl2tpd/xl2tpd.conf
ip range = 您希望對方可以得到哪些ip
local ip = server 對內ip
ex:
[lns default]
ip range = 192.168.0.11-192.168.0.13
local ip = 192.168.0.1
require chap = yes
refuse pap = yes
require authentication = yes
name = LinuxVPNserver
ppp debug = yes
pppoptfile = /etc/ppp/options.xl2tpd
length bit = yes
5. 修改 /etc/ppp/options.xl2tpd
ms-dns = 內部ms dns的ip
ex:
ipcp-accept-local
ipcp-accept-remote
ms-dns 192.168.0.2
noccp
auth
crtscts
idle 1800
mtu 1410
mru 1410
defaultroute
debug
lock
proxyarp
connect-delay 5000
6. ipsec 設定(預先共用金鑰)
6.1 設定 psk (pre-shared-key)
vi /etc/ipsec.d/william.secrets
%any: PSK "your shared key"
server_ip: PSK "your shared key"
其中 server_ip 是您的server 對外ip,
"your shared key"是你的共用金鑰
6.2 vi /etc/ipsec.conf
version 2.0 # conforms to second version of ipsec.conf specification
# basic configuration
config setup
# Debug-logging controls: "none" for (almost) none, "all" for lots.
# klipsdebug=none
# plutodebug="control parsing"
# For Red Hat Enterprise Linux and Fedora, leave protostack=netkey
protostack=netkey
nat_traversal=yes
virtual_private=%v4:10.0.0.0/8,%v4:192.168.0.0/16,%v4:172.16.0.0/12
oe=off
# Enable this if you see "failed to find any available worker"
nhelpers=0
#You may put your configuration (.conf) file in the "/etc/ipsec.d/" and uncomment this.
#include /etc/ipsec.d/*.conf
conn L2TP-PSK-NAT
rightsubnet=vhost:%priv
also=L2TP-PSK-noNAT
conn L2TP-PSK-noNAT
authby=secret
pfs=no
auto=add
keyingtries=3
rekey=no
ikelifetime=8h
keylife=1h
type=transport
left=<你的對外ip>
leftprotoport=17/1701
right=%any
rightprotoport=17/%any
7. ppp 設定
vi /etc/ppp/chap-secrets
加上
william * test *
其中william 是帳號, test是密碼
8. 修改 /etc/rc.local , 加上
8.1 開啟nat,底下192.168.0.0是內部ip範圍(eth1是您的對外網卡)
iptables -t nat -A POSTROUTING -o eth1 -s 192.168.0.0/24 -j MASQUERADE
8.2 允許ip_forward
echo "1" > /proc/sys/net/ipv4/ip_forward
8.3 確認server是否自動啟動, 或是加在/etc/rc.local
/etc/rc.d/init.d/ipsec start
/usr/local/sbin/xl2tpd -D &
9. 重開機(reboot),確認是否完備
ps.
1.要驗證ipsec 請執行
ipsec verify
要記得看log,有時候會遇到不預期的情形,此時就可以看log解決
/var/log/secure
/var/log/message
2. 若還有問題,請嘗試以下設定
vi /etc/sysctl.conf
net.ipv4.conf.default.rp_filter = 0
net.ipv4.conf.all.send_redirects = 0
net.ipv4.conf.default.send_redirects = 0
net.ipv4.conf.all.log_martians = 0
net.ipv4.conf.default.log_martians = 0
net.ipv4.conf.default.accept_source_route = 0
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.default.accept_redirects = 0
net.ipv4.icmp_ignore_bogus_error_responses = 1
測試環境
linux CentOS 6
kernel 2.6.32
windows xp client
(一) 新增連線
1. 開始->設定->網路連線->新增連線精靈
2. 選擇連線到公司網路(使用指定撥號或是vpn)
3. 選擇虛擬私人網路連線
4. 輸入名稱(可以隨意選)
5. 輸入vpn server IP
(二) 修改設定
1. 找出此VPN連線的TCP/IP設定, 選進階設定, 拿掉"使用遠端網路的預設匣道"
2. 找出"預先共用金鑰",然後輸入PSK(pre-shared key),請看上面步驟6的金鑰密碼
3. 若是xp, 請取消勾選"要求資料加密(如果沒有加密就中斷連線)"
這樣就可以了
如何在CentOS 6 下安裝L2TP VPN SERVER
