SMTP 錯誤參考資料
421, "4.4.5", Server busy, try again later. (伺服器忙碌中,請稍後再試。)
421, "4.7.0", IP not in whitelist for RCPT domain, closing connection. (IP 不在 RCPT 網域許可清單中,正在關閉連線。)
421, "4.7.0", Our system has detected an unusual rate of unsolicited mail originating from your IP address. To protect our users from spam, mail sent from your IP address has been temporarily blocked. (我們的系統偵測到您的 IP 位址發出了數量龐大、來路不明的電子郵件。為了讓使用者免於垃圾郵件騷擾,您的 IP 位址所發出的電子郵件已遭暫時封鎖。) 請參閱我們的大量電子郵件寄件者規範。
421, "4.7.0", Temporary System Problem. Try again later. (系統暫時發生問題,請稍後再試。)
421, "4.7.0", TLS required for RCPT domain, closing connection. (RCPT 網域需要 TLS,正在關閉連線。)
421, "4.7.0", Try again later, closing connection. (正在關閉連線,請稍後再試。)
450, "4.2.1" The user you are trying to contact is receiving mail too quickly. Please resend your message at a later time. If the user is able to receive mail at that time, your message will be delivered. (您嘗試傳送郵件的使用者接收的郵件過多,請稍後再重新傳送郵件。如果到時收件者可以接收郵件了,系統就會將您的郵件傳送給對方。) 如需更多資訊,請參閱這篇文章。
450, "4.2.1", The user you are trying to contact is receiving mail at a rate that prevents additional messages from being delivered. Please resend your message at a later time. If the user is able to receive mail at that time, your message will be delivered. (您嘗試傳送郵件的使用者正在接收大量郵件,因此無法再接收其他的郵件,請稍後再重新傳送郵件。如果到時收件者可以接收郵件了,系統就會將您的郵件傳送給對方。) 如需更多資訊,請參閱這篇文章。
451, "4.3.0", Mail server temporarily rejected message. (郵件伺服器暫時拒絕接收郵件。)
451, "4.3.0", Multiple destination domains per transaction is unsupported. Please try again. (單一交易不可包含多個目的地網域,請再試一次。)
451, "4.4.2", Timeout - closing connection. (逾時 - 正在關閉連線。)
451, "4.5.0", SMTP protocol violation, see RFC 2821. (違反 SMTP 通訊協定,請參閱 RFC 2821。) 請引導收件者參閱這篇文章。
452, "4.2.2", The email account that you tried to reach is over quota. (您嘗試傳送郵件的電子郵件帳戶已超過配額上限。) 請引導收件者參閱這篇文章。
452, "4.5.3", Domain policy size per transaction exceeded, please try this recipient in a separate transaction. (超過單一交易允許的網域政策大小,請在其他交易中重試這位收件者。)
452, "4.5.3", Your message has too many recipients. (您的郵件收件者數量過多。) 如要進一步瞭解 Google 的傳送限制,請參閱這篇文章。
454, "4.5.0", SMTP protocol violation, no commands allowed to pipeline after STARTTLS, see RFC 3207. (違反 SMTP 通訊協定,在 STARTTLS 之後不可處理指令,請參閱 RFC 3207。)
454, "4.7.0", Cannot authenticate due to temporary system problem. Try again later. (系統暫時發生問題,因此無法進行驗證,請稍後再試。)
454, "5.5.1", STARTTLS may not be repeated. (STARTTLS 不可重複。)
501, "5.5.2", Cannot Decode response. (無法對回應進行解碼。)
502, "5.5.1", Too many unrecognized commands, goodbye. (無法辨識的指令過多,再見。)
502, "5.5.1", Unimplemented command. (無法實作指令。)
502, "5.5.1", Unrecognized command. (無法辨識指令。)
503, "5.5.1", "EHLO/HELO first. (EHLO/HELO 優先。)
503, "5.5.1", MAIL first. (MAIL 優先。)
503, "5.5.1", RCPT first. (RCPT 優先。)
503, "5.7.0", No identity changes permitted. (系統不允許變更身分。)
504, "5.7.4", Unrecognized Authentication Type. (無法辨識驗證類型。)
530, "5.5.1", Authentication Required. (需要驗證。) 詳情請參閱這裡。
530, "5.7.0", Must issue a STARTTLS command first. (必須先發出 STARTTLS 指令。)
535, "5.5.4", Optional Argument not permitted for that AUTH mode. (這個 AUTH 模式不接受選擇性引數。)
535, "5.7.1", Application-specific password required. (需要應用程式專用密碼。) 詳情請參閱這裡。
535, "5.7.1", Please log in with your web browser and then try again. (請使用您的網路瀏覽器登入,然後再試一次。) 詳情請參閱這裡。
535, "5.7.1", Username and Password not accepted. (系統不接受使用者名稱和密碼。) 詳情請參閱這裡。
550, "5.1.1", The email account that you tried to reach does not exist. Please try double checking the recipient's email address for typos or unnecessary spaces. (您嘗試傳送郵件的電子郵件帳戶不存在。請仔細檢查收件者的電子郵件地址是否有拼寫錯誤或多餘的空格。) 如需更多資訊,請參閱這篇文章。
550, "5.2.1", The email account that you tried to reach is disabled. (您嘗試傳送郵件的電子郵件帳戶已經停用。)
550, "5.2.1", The user you are trying to contact is receiving mail at a rate that prevents additional messages from being delivered. (您嘗試傳送郵件的使用者正在接收大量郵件,因此無法再接收其他的郵件。) 如需更多資訊,請參閱這篇文章。
550, "5.4.5", Daily sending quota exceeded. (超過每日傳送配額。) 詳情請參閱這裡。
550, "5.7.0", Mail relay denied. (郵件轉發遭拒。)
550, "5.7.0", Mail Sending denied. (郵件傳送遭拒。) 如果寄件者的帳戶遭到停用或是並未在您的 Google Apps 網域中註冊,便可能發生這項錯誤。
550, "5.7.1", Email quota exceeded. (超過電子郵件配額。)
550, "5.7.1", Our system has detected an unusual rate of unsolicited mail originating from your IP address. To protect our users from spam, mail sent from your IP address has been rejected/temporarily blocked. (我們的系統偵測到您的 IP 位址發出了數量龐大、來路不明的電子郵件。為了讓使用者免於垃圾郵件騷擾,您的 IP 位址所發出的電子郵件已遭封鎖。) 請參閱我們的大量電子郵件寄件者規範。
550, "5.7.1", Our system has detected that this message is likely unsolicited mail. To reduce the amount of spam sent to Gmail, this message has been blocked. (我們的系統偵測到這封郵件可能來路不明。為了減少傳送到 Gmail 的垃圾郵件數量,這封郵件已經遭到封鎖。) 如需更多資訊,請參閱這篇文章。
550, "5.7.1", The IP you're using to send mail is not authorized to send email directly to our servers. Please use the SMTP relay at your service provider instead. (系統未授權您使用該 IP 直接將電子郵件傳送至我們的伺服器,請改為使用服務供應商的 SMTP 轉發功能傳送。) 如需更多資訊,請參閱這篇文章。
550, "5.7.1", The user or domain that you are sending to (or from) has a policy that prohibited the mail that you sent. Please contact your domain administrator for further details. (您要傳送或是用來發送郵件的使用者帳戶或網域設有禁止這封郵件的政策。如需進一步瞭解詳情,請與您的網域管理員聯絡。) 如需更多資訊,請參閱這篇文章。
550, "5.7.1", Unauthenticated email is not accepted from this domain. (這個網域不接受未經驗證的電子郵件。)
552, "5.2.2", The email account that you tried to reach is over quota. (您嘗試傳送郵件的電子郵件帳戶已超過配額上限。)
552, "5.2.3", Your message exceeded Google's message size limits. (郵件大小超過 Google 允許的上限。) 請參閱我們的郵件大小規範。
553, "5.1.2", We weren't able to find the recipient domain. Please check for any spelling errors, and make sure you didn't enter any spaces, periods, or other punctuation after the recipient's email address. (我們找不到收件者的網域。請檢查是否有拼寫錯誤,並確認您並未在收件者的電子郵件地址後面輸入任何空格、句號或其他標點符號。)
554, "5.6.0", Mail message is malformed. Not accepted. (郵件格式錯誤,系統無法接收。)
554, "5.6.0", Message exceeded 50 hops, this may indicate a mail loop. (郵件傳送路徑包含超過 50 個躍點,這可能是郵件遞送迴圈。)
554, "5.7.0", Too Many Unauthenticated commands. (未經驗證的指令過多。)
555, "5.5.2", "Syntax error. (語法錯誤。)
SMTP 錯誤參考資料
正在瀏覽這個版面的使用者:沒有註冊會員 和 2 位訪客
