如何在CentOS 5.4 下安裝VPN(l2tp/ipsec) Server
1. 安裝openswan, ipsec , ppp
直接用CentOS裏面即可
2. 安裝xl2tpd(http://www.xelerance.com/software/xl2tp ... 2.4.tar.gz)
解開後進入該目錄,執行
make
此時無法編譯成功, 但是已經可以看到xl2tpd這個檔案了
因此可以
cp xl2tpd /usr/local/sbin/
mkdir /etc/xl2tpd
cp examples/xl2tpd.conf /etc/xl2tpd/
3. 安裝rp-l2tpd (彌補xl2tpd 1.2.4 無法完整編譯)
http://sourceforge.net/projects/rp-l2tp/
下載後解開,進入該目錄,後執行
./configure
make
cp handlers/l2tp-control /usr/local/sbin/
mkdir /var/run/xl2tpd
ln -s /usr/local/sbin/l2tp-control /var/run/xl2tpd/l2tp-control
4. xl2tpd 設定
修改/etc/xl2tpd/xl2tpd.conf (預設沒有此檔)
ip range = 您希望對方可以得到哪些ip
local ip = server ip
ex:
[lns default]
ip range = 192.168.0.11-192.168.0.13
local ip = 192.168.0.1
require chap = yes
refuse pap = yes
require authentication = yes
name = LinuxVPNserver
ppp debug = yes
pppoptfile = /etc/ppp/options.xl2tpd
length bit = yes
5. 修改 /etc/ppp/options.xl2tpd
ms-dns = 內部ms dns的ip
ex:
ipcp-accept-local
ipcp-accept-remote
ms-dns 192.168.0.2
noccp
auth
crtscts
idle 1800
mtu 1410
mru 1410
defaultroute
debug
lock
proxyarp
connect-delay 5000
6. ipsec 設定
5.1 設定 psk (pre-shared-key)
vi /etc/ipsec.d/william.secrets
%any: PSK "your secret key"
server_ip: PSK "your secret key"
其中 server_ip 是您的server ip
5.2 vi /etc/ipsec.conf
加上此段
include /etc/ipsec.d/examples/*.conf
主要是include no_oe.conf,l2tp-psk.conf,若examples下沒有這檔案,請找我要
7. ppp 設定
vi /etc/ppp/chap-secrets
加上
william * test *
其中william 是帳號, test是密碼
8. 開啟nat,底下192.168.0.0是內部ip範圍
iptables -t nat -A POSTROUTING -o eth1 -s 192.168.0.0/24 -j MASQUERADE
9. 設定網路相關設定是否開啟
/etc/sysctl.conf
net.ipv4.conf.default.rp_filter = 0
net.ipv4.conf.all.send_redirects = 0
net.ipv4.conf.default.send_redirects = 0
net.ipv4.conf.all.log_martians = 0
net.ipv4.conf.default.log_martians = 0
net.ipv4.conf.default.accept_source_route = 0
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.default.accept_redirects = 0
net.ipv4.icmp_ignore_bogus_error_responses = 1
10. 重開機(reboot),確認是否完備
11. 啟動 server(建議加在/etc/rc.local)
/etc/rc.d/init.d/ipsec start
/usr/loccal/sbin/xl2tpd -D &
12. 若有使用防火牆,記得開放 udp 500, 4500, tcp 4500 , 以及允許 -i eth0(eth0 對外)
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 4500 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m udp -p udp --dport 500 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m udp -p udp --dport 4500 -j ACCEPT
-A RH-Firewall-1-INPUT -i eth0 -j ACCEPT
ps. 要驗證ipsec 請執行
ipsec verify
要記得看log,有時候會遇到不預期的情形,此時就可以看log解決
/var/log/secure
/var/log/message
測試環境
linux CentOS 5.4
kernel 2.6.18
Windows XP client 設定
(一) 新增連線
1. 開始->設定->網路連線->新增連線精靈
2. 選擇連線到公司網路(使用指定撥號或是vpn)
3. 選擇虛擬私人網路連線
4. 輸入名稱(可以隨意選)
5. 輸入vpn server IP
(二) 修改設定
1. 找出此VPN連線的TCP/IP設定, 選進階設定, 拿掉"使用遠端網路的預設匣道"
2. 找出"安全性" , 拿掉要求資料加密, 以及"ipsec 設定"選項,輸入PSK(pre-shared key)
這樣就可以了
CentOS 5.4 VPN(ipsec/l2tp)設定, 可讓windows簽入
