mrtg 錯誤訊息
mrtg 錯誤訊息
執行/usr/bin/mrtg /etc/mrtg.cfg 後出現下面訊息
ERROR: Mrtg will most likely not work properly when the environment
variable LANG is set to UTF-8. Please run mrtg in an environment
where this is not the case. Try the following command to start:
因為mrtg LANG是Big5 而主机的是UTF-8所以要改執行
env LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
正在瀏覽這個版面的使用者:沒有註冊會員 和 6 位訪客
